The rear sits just where I want it to which is great. The fronts could do with being 5 - 10mm lower. This is not much I know but I would love it to be perfect. However I might hold off till I get the new rims and then get all the fiddley bits sorted once and for all.
In the meantime....picked up this bad boy - or one like this actually...no pic yet :)
post-18475-12685589506895_thumb_zps6056f
Cheers Matt....yeah once i get the new rims on and go a tad lower I will be happy with the exterior.
Update....
Putting in the monkey bar first thing tmrw morning.
Getting new coilovers in three weeks.
New camber arms are on and looks much better now.
Monkey bar installed....not without a fair bit of monkeying around though - the bloody thing was a pain in the ass to bolt in with the carpet which I had to cut in places :(
I did however put in new carpet inserts which I will get my little sister to stitch to the existing bits.
Looks awesome though and I am well on my way to having my own personal go kart
Annnnnddddd.....got my other bootlid back all painted and shiny.
Will mount the carbon wing on to it and we are back in business.
The bling bling "S" in the middle of my bonnet has been bugging me for a very long time.
So I decided to do something about it this morning. Going to paint it black with a clear overcoat. If this does not work I will just remove it altogether.
First step was to mask up the surrounding areas.......Thought about it but did not bother about the gaps in the middle as I am fortunate enough to be painting black on black which will go unnoticed.
Second step was to get out my dremel and sand paper and lightly agitate the surface so that it would hold the primer and paint........
No pics..
Third step was to give it two coats of primer
No pics..
Currently drying....
I am such a messy painter....not to mention entirely wasteful !! :closedeyes:
ETA/specs on rims?
Mid July sometime hopefully. At least I have the tyres ready to go so that will not take long. Got 18x10 +5 (max on a 10 inch rim that Work make with O Disk)
In other news.......ended up de-badging as the black looked pretty mediocre to be honest. Took me the better part of two hours to get the badge off with a hairdryer, thread and a precision hobby knife set...and then some good ol' prepsol and heavy buffing and it now looks sweet :)
This was when it first came off and left sticky marks.
This was after prep sol and heavy buffing
Used a layer of colour cure plus rubbish that I had lying around in the shed too.....must say for a cheapish brand it worked wonders....quite impressed
Also....my mirrors have suddenly stopped adjusting.....so went to check the fuse and realized I had about as much chance as scoring with Ellie Goulding as I had of deciphering the language. So I proceeded to print this bad boy out..........
Which was too big....so reduced it and laminated it
and gave the trim a freshen up wittttttttthhhhh......you guessed it.....black acrylic from supercrap
i can slightly see where its been. dont have OCD do yah? haha
NO YOU CANT MATT !! Stop being a dingbat !!
and OCD and me.....rubbish....lol :)
Can confirm this guy has serious OCD issues...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
