Looks sick! Now please lower it... just a cm lower will make a world of difference, especially to the front..
Beginning to accept the truth in that statement.......maybe I should surprise myself with some new Teins as an xmas present.
....because parking close to the kerb is overrated ;)
  • Like 1
Update :)
Have always felt guilty for not having a GTR passenger seat and when I saw a great deal on bookface earlier this evening I could not resist picking up these bad boys......
Thank you to Jack :)
Edited by jez NF
This is what the inside of the wheel adjuster thingie looks like btw for anyone struggling to remove it so that you can take the plastic trim off...on the previous seat it took me over half an hour to get a flat head screwdriver in there to wedge open the circlip !! Anyways...the plastic bits are going to be painted first thing tomorrow.
After a bit of internet research over the last few days, I decided to just YOLO (you only live once - I did not know what it meant either initially..hahaa) and this happened...........
P.S. If I end up with a black back and bum don't try this at home !!
Everyone knows what stock seats with factory material that looked good 18 odd years ago looks like nowadays.
So there is going to be no picture for that.....
(insert picture of faded GTR seat)
This is after the first light coat...
This is after I turned up the heat and went with another two coats....
Getting my black on....
It is bound to dry patchy for the first few coats...so I am not too worried...but hopefully after a few thousand coats it will be nice and even !!
P.S. It is drying up quite nicely actually as I type this and has begun to look pretty good YAY !!
NOW TO SEE IF IT RUNS WITH SWEAT !!
Also (since I forgot earlier) shout out to Joel for being an absolute gem of a mate and remembering that I wanted tinted indicators and selling me his. Beats my DIY tinted ones any day. Though in all fairness to myself I was trying to tint amber lens..haha. Pictures tomorrow !!
Picked up a spare set of these to have a little play with replacing the amber with a clear lens....will see how we go. Thanks to...umm...what was his name now...oh yes Anthony !! :)
Tinted indicators fitted
2c6448ab-2524-4a65-b5aa-db7a3b0d5e39_zps
The seat is looking real nice.....will do two more coats to seal in the colour and ensure it has a nice smooth finish
Really impressed with how easy it is to do and it turned out not as patchy as I thought it was going to be.....HOWEVER the decisive bit is going to be if the colour runs....which we shall soon find out
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
