Refresh the carpets time. Old job I did was getting on in age and thought it would be nice to spruce it up again.
Bunnings do a nice thinner more pliable version as well so very keen to have this one up and running and see how hard it is to massage into shape.
  • Like 1
  • 1 month later...
12 hours ago, jez NF said:
New seats and harnesses are 90% in. Few more bits to tidy up which I should have done in the next couple of weeks.
Looking great so far !
Damn they look fantastic!
  • Like 1
  • 1 month later...
  • 1 year later...
  • 1 month later...
Posted (edited)
So I ride and race motorcycles for fun and have always used a van to transport my track weapons. Figured towing a racebike with a skyline would be different and if done right could - "look fully sik" or quite cool for us grown ups lol.
Pic of yours truly on two wheels
I also have a trailer already kitted out to transport my bikes
...and I have a spare set of rims that match the car that I was going to rebarrel to get deeper dish at some stage but they have just been gathering dust.
Sooooooo it is only logical....
Stay tuned !!
Edited by jez NF
Grammar
  • Like 3
Trailer prep is underway...
Lined up the wheel to get a rough indication of how it would sit
Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint
Then added some carpet
  • Like 1
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
