On 22/6/2025 at 9:45 PM, Milkmun said:
The stealth of it is sick. Custom tow bar I assume?
Yes customized and built from scratch pretty much after finally finding a local towbar supply and install place that was willing to do something "different".
Very happy with it for sure 👌
  • Like 1
Do you mind if I ask how much this cost to get setup?
Currently I put a rear rack on my bike, load up a duffle bag and ride to the track. The ride home can get a bit sketchy with how exhausted I am, if this isn't crazy expensive it would be a much better option for sure.
  • Like 2
It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.
Hardest part was finding someone willing to customize and fit it up with trial and error basically.
Whereabouts are you located? - I had my work done locally in Wangara.
It sounds "expensive" when compared to a mass produced tow bar that gets imported from China, but if that's all custom fabrication, then I think where you've ended up, it's a pretty good price! Considering some people will pay thousands of dollars for a few intercooler pipes to be welded up!
  • Like 1
Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.
I'm a long way from you mate, I'm a couple of hours out of Brizzy.
  • Like 2
  • 3 weeks later...
Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
att.HD-mjlbhCOHOTxHzOJxx3GbigiUtMbN5pJOJrz6cJeQ.thumb.jpeg.f4bf325a1f31a714be6b9b3d177b6efd.jpeg
  • Like 2
10 minutes ago, GTSBoy said:
Given the absence of lower parts, I'd suggest that they are just draped over the backrest for aesthetics in the photo.
I'm guessing its a 4 point harness, 3 of the 4 belts are visible. I'm guessing the hidden belt is tucked down between the seat and door.
  • Like 1
Lower parts are there. On passenger seat, bright yellow bit is the release mount. On drivers, bright yellow bit is the lower buckle for the other side.
My bet is lowers are tucked out of the way as much as possible for visuals.
  • Like 1
  • 3 weeks later...
  • 1 month later...
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
