hahaha 406.74MPH!
Too bad the lady wrote incorrect speed on it. But I did get one where it says 192.38MPH.
Anyways thanks to all involved for organising this. Too bad it was wayyyy tooo hot! >.<
192MPH!! on the left:
  • Replies 114
I'm stoked, I got a 14.507 @ 91.6mph on low boost (9psi) in the morning with a fair bit of knock due to the heat (it was already close to 30degC at around 10.15am). This was my second run, and I've never dragged before.
In the arvo with the cooler weather, I did a few more runs in low boost to check for knock, then went for it in high (12psi) and got my best run of a 13.817 @ 95.23mph on my second last run.
Not bad for an RB25DET Stagea with minimal mods (full exhaust, return-feed FMIC, PowerFC, EBC and fuel pump) running an otherwise standard engine and turbo. I wish I'd remembered to check the weight during scruitineering, but it would quite easily top 1700kgs.
:banana::bunny::banana::bunny::banana::bunny:
Massive thanks to all the SAU-NSW Exec crew (Eric, Dave, Duncan, Liz, Shell, Steve-O, etc.) and our volunteer support network (BenM, Sean, Mitch, etc.) for putting this together.
Also thanks to our very own Tats for the commentary throughout the day, he sounded much more professional than I did over the PA system
Funnist moment in there-
Me " just a little lower Louise"
Bahahaha. I still find that funny!! Lol
Thanks to all for a great day, well run.
Only had eleven runs due to the heat, car run like a swiss watch all day, worst run was my first with a 12.7, best was a 11.3.
took plenty of pics and vid, will post up later. :thumbsup:
BIG Thanks to Dave and the SAU team for hosting such a great day cant wait till the next 1(if i can come again)
Ran 11.4 on the fist run on low boost then 11.7 on the 2nd but the block split half track witch ended my day
Highlight off the day was watching the silver Skyline with the Microtech sticker on the side off it running a 12 at 130mph this thing was sideways from the start to the finish line he must have big balls to drive something like that
Thanks again Todd (Black Dato 1600)
Was a great day me and my wife were there for the nissansilvia.com drifting,
But we spent half our time watching the drags, one of the best days out we've had in a while
I thought I saw you out there, but wasn't sure if it was. You were both wearing black?
Thanks to SAU:NSW for organising a great event, shame the car called it quits just before lunch (silver 1600).
Had 4 and a half runs, best was the very first one of 11.6 @ 123mph 1.8 60ft
Best mph was 125
Awesome to be able for have 4 runs within an hour, compared to 1 run per hour on Wednesday nights.
Picture of snapped cv spline.
Aww really you should have said hi, yeah that was us, I don't own anything that's not black, I was there with my new 200sx Im considering buying a track only s13 or r32 for drifting now
Nice one Pete :) I better pull my finger out and run a decent number in the 200 or your going to catch and pass me :D
Not likely mate. 2 second 60fters for the rest of the runs
Speaking of Pro street towing......Joe towed me back home after I broke my cv - nice guy to come out on a nice Sunday afternoon
I hear from him the car is back at UE for the injectors - had mind put in an tuned on the Thursday night.
YOU MOFO'S WANT SOME PICS???
If you entered and arrived on the day you'll have a disc sent to you in about a fortnight. Until then here's a a few to keep you going :D
LOLvo
damn double watermark. grrrrrrrrrr
Will add a few more tomorrow morning if your good tonight.
Edited by MaTBoY
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
