I will try to upload the dyne sheet. Also has anyone else noticed the info missing from the bottoms of staos dyno results. Without all the extra info they look rather false.
Just a note I wouldnt be this pissed off it atleast made the same hp as the stock turbo. It fell a few hp short of the stock turbo. I know different conditions may be at fault but yeah for $100 more I could have had a better turbo without all the extra problems of installing a chinese/eBay turbo.
You made over 306.4hp (228.48kw) on the factory turbo? At what boost? That sounds awfully high (unheard of), especially from what I've seen in the dyno thread.
  • Replies 56
i just noticed i miss typed, sorry, it was suposed to read "it feels a few hp short of the stock turbo"
The turbotech boost-T are the best of the manual controllers. $30 off eBay, superior to your current turbosmart unit. Check the lines from the turbo for a small split.
The stock turbo will probably be more responsive since its small and very light.
Whilst your new turbo may get going only 300-500rpm higher in the revs, its right in the most-used range, so you're going to notice.
However, once it starts to sing, there should be no comparison with the stock turbo - it should pull pretty hard although looking at the dyno graph the boost does fade pretty rapidly.
While we're on the topic of boost controllers, I'll give another vote for the turbotech one off ebay, but as noted in earlier comments, probably not a good choice for high boost applications.
The turbotech works well around 10-12psi, maybe a little more, but anything over say 14psi really needs a decent controller.
Hope you get it sorted.
I really would like to get a blitz boost control as ive got a blitz fatt. But I thought blitz had been sold and they are a different brand now. But I saw one on eBay. So yer :/
  • 3 weeks later...
We have wuite a few guys running 30-32psi on teh original controller but yeah teh new V2 isi far superior at high boost..In fact it holds 60psi rock steady under test and to be honest I havent even tried to find its max. it's all in teh desin of the seat and teh speciallly imported ball for the gate that seals solid. Normally gated controllors have a hard metal ball on a metal seat..teh V2 has a metal seat but teh special ball is not metal or ceramic. It is hard but has some flexion so it seals tight.
Cheers.
Mark form Turbotech Performance
Why do there seem to be heaps of people who like the Blitz dual solenoid units?
I don't really understand why you'd need two solenoids, and why Blitz seem to be the only people peddling a dual solenoid EBC.
I think it's something like one of the solenoid valves adjusts in big increments and the other in small increments. So with the two working together you can get better resolution/control than units with just one solenoid.
Why do you think the Mac valves are good for automotive applications? Some of the plant that I maintain uses banks of Mac valves and they are still going strong after 10 years, but this is with filtered / dried / cooled air. So I think they are a reliable valve but performance wise I don't know, they still only do the same job as all the festo, smc, norgren valves we use.
PS my gizzmo unit uses a Mac valve and it does the job well.
I installed an IEBC on the weekend & ended up using the factory solenoid to do the control, just rerouted the hoses & wired it up to my controller.
I tested a solenoid I had bought 15 years ago, but it didn't want to pulse reliably above about 30% duty cycle so gave it the flick in favour of the one Nissan already supplied, thanks guys :thumbsup:.
A Mac valve would be better...
I ran a small MAC on my Haltech setup for about 6 years - worked fine. I'm just using an adjustable wastegate actuator rod on y DR now because it's only running around 9psi, but I might build another IEBC and see how responsive I can make the old TO3...
You can just see it (circled) in this old photo when it was fitted to my Z.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
