saw it at autosalon yesterday, was a series 2 r33 with the plates PUNKD(i think there is meant to b a pun in there), and inside the engine bay there was a Phat Eaton(i think) positive displacement supercharger, no turbo to b found. my guess is it was originally NA and he made the switch to blow it, pretty unique i think.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/
it was messed up graphically... it had robotech side graphics and a big arse transformers autobots sign on the front... and also the word transformer somthing on the side next to veritech fighter off robotech... very bad mistake if you're a robotech or transformer fan (both of which I am).
The supercharger amazed the f**k thru me, but I could never find the owner around the car to drill him for questions... I've got pics of that engine setup from every angle so I should be able to find out who made it (and possibly get a replica) :)
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760230
Eaton supercharger. Maybe ask an eaton s/c dealer in victoria.
I was almost hoping there was a turbo underneath the manifod, but sadly none, just pipe leading straight to exhaust :)
I'd imagine it should be near to stock RB25DET output power with fatter down low torque curve, as most s/c are low boost induction around 6-7psi and works well at lower rev range.
I suppose ECU should have been changed as well. I was here today and seen no one standing by to be asked some questions too. Oh well... leave us wondering.....
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760250
Then could it be an RB25DET with turbo replaced with the super charger. Considering both stock boost and supercharger is the same, engine and ecu could cope with it. The only difference is that you get instant boost right from idle. No lag.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760336
well theoretically a Supercharger is a non invasive upgrade, ie it does not require that you modify any internals, or exhaust system. you don't neeed new headers.
So realistically for an N/A its pretty cheap alternative.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-782431
Ive seen him run at sat nigh church. Nothing special, keeps up with most other cars it ran.
and yes wtf is with mixing the robotech veritech with fuggin autobot tranformer emblem? oooh he should be shot (im a robotech transformer fan of ye OLde)
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-783803
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
