I have a question regarding E10 fuel.
Now i know that its a blend of unleaded + %10 ethonal and is a lower Octane rating , but i have been searching on the net and discovered the following at "Freedom Fuels" which actually has 3 diferent types of E10...
E10 Unleaded (91)
http://www.freedomfuels.com.au/index.php?option=com_content&view=article&id=15&Itemid=20
E10 Premium (95)
http://www.freedomfuels.com.au/index.php?option=com_content&view=article&id=16&Itemid=20
E10 Hi Octane (98)
http://www.freedomfuels.com.au/index.php?option=com_content&view=article&id=17&Itemid=20
So my question is that would it be ok to use the E10 Hi Octane as its equivelent to 98 proof premium unleaded?
Regards,
Darren..
https://www.sau.com.au/forums/topic/378246-e10/
Any E10 is safe to use and the higher octane the better.
For highly tuned engines the problem is the same as with E85 although on a smaller scale - namely that the actual ethanol content and rating of the fuel can vary which matters when your engine is tuned to the outer limits. For such engines the way forward seems to be the "flexi" approach where the fuel quality is sampled by a special sensor before it reaches the injectors and an adjustment made automatically through your Link, Vipec or other high performing aftermarket ecu.
However for stock or less modified engines the difference particularly with E10 should not be significant.
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6031856
I'm using the United Premium 100 fuel, which has become available again at my local servo. 100 octane E10, and my car seems to run better on it. Always had good results when running it in the past.
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6032149
Does it cost extra? If the car is tuned on 98 octane fuel, will it be fine switching to this? Are there any risks of running this octane stuff? I have heard alot of stories of the ethanol ruining old components in the fuel setup, corroding shit, etc. Sure these cars run now but is there any negative long term effects
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6032637
so United sell e10 100 octane...might have to check that out and put 1/2 tank in when empty to see if there is a diference between that & vortex..
Thanks for the input guys, would love to do e85 but there isnt much around and cant afford more injectors presently but but the e10 may helpp a bit....
How does it vary in price to the 2 premuim brands & what the economy like guys?
Regards,
Dazza
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6033083
I find the 100 to be similarly priced to Ultimate.
I think the E10 does corrode in older cars. R31s are on the list of cars that cant run E10 (without upgrading the fuel lines), but modern cars are fine.
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6033093
uh oh, i think thats all that my gf's 31 ever gets :(
on topic, i run the e10 95 in my stagea (way cheaper than the 98 we get here) and it runs pertty well (rb25 neo)
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6033808
Funny, I remember it being in one of those government pamphlets when E10 first came out as being on the 'do not use' list. Maybe it was just paranoia on their behalf? I never bothered to double check it, just didn't use it.
https://www.sau.com.au/forums/topic/378246-e10/#findComment-6034838
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
