hi just wonder in if someone can help me with a question now i'm running 235/35/19 tires (toyo t1r's) i was saying to a mate about getting a fair bit of wheel spin at last track day he reckon's that i wouldn't be getting as much if i had 17's or 18's can anyone tell me if there is any truth in that? cheers
https://www.sau.com.au/forums/topic/378554-wheel-spin/
Nothing is ever perfect and everything is a compromise. Cars do three basic things and a mix of all at times. The accelerate, the corner and they brake. A tyre that is good at one may not be good at the others or even all three.
Generally more sideall will give you better longitudinal grip, braking and power down...but if you are trying to go through corners as well..... like I said, everythings is a compromise.
Frankly, a low profile 19" car should work perfectly fine if its a good quality tyre and your suspension is set up for it. If you have big, baggy side walls then you can generally run harder suspension as the tyre acts as a damper. If you have low profile tyres with no side wall then you need more compliance in your suspension
https://www.sau.com.au/forums/topic/378554-wheel-spin/#findComment-6037384
Regardless of how the actual tyre itself performs, a 17" wheel and tyre will weight less than a 19" wheel and tyre of the same overall diameter. And the lower the wheel weight, the better the carw ill behave on the track (and on the road - even more so because the road has more bumps).
Something worth remembering is that the 19" version of a tyre is not the same tyre as the 17" version. If the 19" version has to have a much shorter sidewall in order to keep it down to the same overall diameter, then they may need quite different sidewall construction. Regardless of the details of the construction, the 19" sidewall will have to be much stiffer in order to keep the rim off the road, and that lack of compliance will hurt some aspects of the tyre's performance. As noted by Roy, above. On a really really smooth track it might be reasonably pleasant in the corners (a stiff sidewall generally giving good grip but with the risk of not offering much warning of when it's going to let go) - but you'd still expect the lack of sidewall give to cost you in longitudinal grip and hence lead to more wheelspin.
The short version? People often prefer 17" wheels for track use over 18" wheels. That leaves 19" wheels out in the cold.
https://www.sau.com.au/forums/topic/378554-wheel-spin/#findComment-6037429
smaller wheels will give you more sidewall and can provide more grip, but not as much as better tyres or better setup
Agreed, essentially this
tho dont run out and buy 17's n new rubber if that is what you are thinking. Go for setup first. Second- Upgrade the tyres if you are chasing more grip and even get a tyre with a bigger sidewall to counter the effects related to the above comment about sidewalls and grip.
last resort would be lashing out on new size rims n tyres in the pursuit of grip.
i cant remember which episode it was but im prety sure top gear or some review show ran a car round the test track with the 'optional 20" rims' and then with the standard 18's or 19's. The 20's were way slower and more of a handful to control the car on...
there is a reason F1 cars have sidewalls that are Huuuuuuge...
https://www.sau.com.au/forums/topic/378554-wheel-spin/#findComment-6037538
You have to differentiate between tyres/rims that contribute to what some perceive as looks and those that function well. The 20" HSV rims do neither IMHO. Bit like the cars themselves.
As someone who uses 17" the reason is not because I believe them to be better than their 18" counterparts. They arent. The reason is that they are cheaper - about $500 a set cheaper for R compounds.
R compounds, relative to road tyres, have very stiff sidewalls. Tyres with too low air pressure on the other hand, dont. A drag tyre is the extreme example. The sidewals are designed to give and thereby provide good traction.
Oh and for what it is worth that if you have a proper rim/tyre package the rim is lighter than the tyre.
https://www.sau.com.au/forums/topic/378554-wheel-spin/#findComment-6037638
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
