Hey guys just wondering how well you know your 260pon cams rb26.... To start off all shims are adjusted correctly.
OK well my cams have an aggressive over lap causing a serve low compression reading for example... the piston travels down, inlet valve opens, piston reaches bottom of cylinder and begins to come up and the inlet is still open.
it causes a low comp reading of about 100 and i drop in stock cams and it goes all the way to a strong 150. can anyone shed some light on their overlap?
All cams will cause loss of compression with valves being open during the compression stroke
I.e the cams i got are 252 & 262 @ 0.050" at 10.75:1 static compression ratio dynamic compression ratio is roughly around 8.5:1
Valve over Lap is when the exhaust valve is closing and the intake is opening at the end of the exhaust stroke/ beginning of the intake stroke
Adjusting cam timing via dialing in which should be done with all new cams or on a dyno / series of road tests etc and this will change the valve overlap and can add or take away a percentage of the compression stroke
just had a quick look on the just jap website and they say the pon cams are 260.... yeh i have the adjustable gears does anyone know how many degrease is safe to turn before valves can actually hit piston? and should i turn them clockwise or anti do i turn them bothe in the same direction...?
I had 256 cams and I know people running bigger and they don't seem to have this issue. These cams are setup to be in the optimal position. You shouldn't need to f**k around with cam gears straight off the bat.
I'm fairly sure with the issues you are having you've got one or both cams timed incorrectly, ie. cam pulley is out a tooth.
Check it properly. No offense but you don't seem to have a clue what you are doing so it might pay to have someone that does to check it.
You definitely shouldn't be losing that much compression on such mild cams.
Numbers shown are open, closed and cam centreline.
ATDC = after top.
BTDC = before top.
BBDC = before bottom.
ABDC = After bottom.
ACDC = Shite band much loved by bogans.
Stock cams
Intake 240 degrees 7 BTDC 53 ABDC 113 degrees
Exhaust 236 degrees 63 BBDC 7 BTDC 118 degrees
Tomei Poncam A
Intake 260 degrees 20 BTDC 60 ABDC 110 degrees
Exhaust 252 degrees 61 BBDC 11 ATDC 115 degrees
Tomei Poncam B
Exhaust 260 degrees 65 BBDC 15 ATDC 115 degrees
You can work out the overlap from there - basically the stockers dont overlap and the B's have 35 degrees of it.
Having had them installed then removed I can confirm the Poncam B's take a massive hit on cyl;inder filling at idle.
Edited by djr81
  • Thanks 1
hey thanks for your interest in trying to help, but timing is spot on im tending to lead towards the wrong cams were given to me. might get some other cams as i put standard ones in compression comes back up.
I have 10.8mm lift cams 10vc dome piston and 0.130" intake and 0.180" exhaust piston to valve clearance. but i also have +1mm valves and 0.095" ground off the head and the pistons are sitting above the deck 0.005". Minimum piston to valve clearance is 0.080"
And ac/dc were are good band in the day
Thanks mate most useful bit of information good to see some one who really knows what their talking about thumbsup.gif
ATDC = after top.
BTDC = before top.
Stock cams
Tomei Poncam A
Tomei Poncam B
i better get out the clay and measure my valve to piston clearance in the cylinder whistling.gif hehe.
I think the thing to realise is that opening and closing , valve timing , is related to how the cams are timed when fitted . You can have a pair of std cams set to have a lot of overlap or long cams with SFA overlap .
Its how the cams are set in relation to each other and where the pistons are in the cycle .
If someone with the same cams as you have can tell you where to set their timing and you can degree the crank with the cams their should not be any dramas , always assuming your engine is in good nick .
A .
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
