Won't see the block for a couple of weeks, but thanks for the offer!!
Got the HKS front pipes today as well as,
CP pistons kit
valve guides
Ross toughbond balancer
The block, crank, studs, balancer, clutch and flywheel are now at the engine reconditioners to get cleaned, balanced etc.
Now is it worth it getting the block grout filled to the bottom of the lower water jacket welsh plugs....
Block is getting the full treatment then grubscrewed. Got to remember to tell the engine guy to drill out the oil returns in the block too.
Original engine was pretty clean. Crank, was pretty good, but we shall see.
Windsor engine reconditioners are doing the machining.
The modified oldschool g clamp my dad gave me years ago to do pushrod engines won't cut it on these heads :pirate: , because they are so deep.
And I couldn't be bothered buying one, making/modifying stuff is cool.
keen to hear how much this will be, let me know what Steve does and how much as i've got to get my head sorted out aswell
Went the engine shop this arvo and did some stuff.
Started with weighing the pistons, and difference between lightest and heaviest was 1.1 grams. Weight matched CP pistons to less than 0.1 gram to each other after using linisher and digital scales.
Weighed gudgeon pins and they were all the same.
Then was told that the engine oil could make up 5 grams difference in weight in an engine. Oh well at least they are all the same.
Drilled out the head oil returns to the size of the head gasket.
Crank will get grubscrewed as they use aluminum plugs on the ends of the big end oil drill holes.
Also got to setup a 304 V8 crank with bob weights on a crankshaft balancing machine, what a pain!! At least inline 4's, 6's, 8's don't need bob weights, you just need the pistons, rods etc to be spot on and all the same.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
