  • Replies 41
we pay 50,000 yen a month for our place, which by Japanese (city) standards is both cheap and large (including large garden, twin car garage, and enough parking for several cars outside and a two floor out building with 3 rooms that I use a school). The downside (depending on how you look at it) is it's way out in the countryside with not much in the way of nite life (save for drifting :() and shopping. Though, my area is being rapidly developed, and at the rate it's going it wont be long before I feel I'm living in the city again...:)
I'm in Yamanashi, on a map, find fuji and it's the large valley to the north. 90 mins from Tokyo by train.
massive is a downside when it's an old massive house: freezing in winter and way too bloody hot in summer :):P Worst thing is, I always thought old style Japanese houses were designed so as to remain cool in summer, but our place is anything but! The wood seems to trap the heat, so often it's hotter inside than out! But I can't complain, it is cheap and the location was ideal for what we wanted it for (namely a school). We plan to move out within a couple of years, but our place and all...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
