Where's your sense of adventure?
Lol.
Sense of adventure? It's already proven that the only devices that can read our car's data from the OBD2 port is either the HKS OB-Link or the Greddy Informeter, neither of which has a video output...
That's why I said its not that easy. If it was I'd have my Rasperry Pi already to rock in the car. The HKS OB Link is feasible if someone can port their Android software to Debian...
Can't Raspberry Pi run Android?
One of the guys at work has one and I'm sure he said it could.
Yes it could, but why would I bother when I can get a $130 7" Android Tablet that's 4 times more powerful then a RasPi and already has GPS, BT, Touch input display, storage, etc?
I think if you want to utilise the existing pop up display, a RasPi Carputer would be good, if you want a intergrated look and more flexibility. Other wise a cheap Android Tablet can do it all for cheaper and safer too...
Edited by ironpaw
Then I'm confused why you want their software ported to Debian?
Because Leon suggested a Carputer and a OBD2 connector/cable would work in our car...
IF the HKS Android software was ported to Deb then yes Carputer would work (that's if you want to display all the ECU data). Even then you'll need some sort of touch screen hooked up...
If not then a cheap tab would work just as well, if not better.
Edited by ironpaw
You mean like this one?
http://www.ebay.com.au/itm/Nissan-Infinity-G35-2003-2004-CD-Stereo-Fascia-CT24NS09-/270718155547?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f080f3b1b#ht_2274wt_1393
There are a few options available, I have one here on an RS wreck too. What colour are you after though?
Did a language conversion for someone that had one of these. Buttons look abit out of place but worked perfectly and they were very pleased
Ahh.... we're talking about 2 different things by the looks of it. You appear to want a solution that does everything, including a touch screen overlay to change stuff as you go, correct? Which would be very nice, btw.
I was only talking about displaying a handful of gauges on the screen (as well as having a multimedia player). The UpRev Cipher cable will do that, but there may be cheaper ones around that can read enough of the OBD data to give you something to play with.
Alrdy purchased 1 of those oem items listed in the above post, Actuallt found it cheaper than the other kits out there thru stereo mobs.
I did purchase the metro kit but opened it up & the buttons looked so tacky, so sent it straight back. Got my money back than bam purchased that 1
Not a bad price for what it is, especially compared to CAMP2.
Only problem is you need an Android powered head unit.
Or any tablet with a browser (mainly linked to it for ironpaw). But using a dual DIN head unit to display gauges would be very cool :cool:
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
