Few boxes arrived today!
One rad to replace a leaky one for the Whale, and another for me. A Nismo thermostat, and the motordyne 5/16 plenum spacer.
I'll chuck the rad and thermostat in when I get the next chance, but I'm not going to fit the plenum spacer until I go for my next tune, in case it leans it out too much. Better safe than sorry. Next to the AFM!
IMG_4318[1] by PNM35, on Flickr
Edited by PN-Mad
Put the number plate in the bottom of the bar Craig - looks horrendous there!
lolz........the plate won't stay there....I had to put it somewhere for the trial fit and thats where the holes were from the previous owner!
.......sorry Alex!......I'll stop again now!
So, installed my radiator yesterday. It wasn't "drop in" but it was pretty close. I did modify a couple of little things for future ease. The Nismo thermostat was a bit of a pain. Hard to get that gasket in place, and find the bolt holes. Anyway, its in, and not leaking.
Strapped up the laptop for the trip to work yesterday. Thermostat opens at about 75 degrees, from there temp dropped to 73. once I started warming it up a bit, normal cruising temps were from about 77-82 degrees. If I was at lights, that went up to 88 or so, but soon dropped back down. I got stuck in traffic, and temp went up to the normal 98 where the fans cut in, and I saw a noticeable increase in speed for the temp to drop back down to 93 and fans switch off. So, its a win. No leaks, this morning I topped up the system, and made sure the last of the air was out. I'll check again in a few days time that its fully bled.
Overall its a drop of about 10 to 12 degrees. Normal Cruising temps were just over 90 generally, and at lights you could expect it to go up to 95 to 98. I did have to pick up some barbs from pirtek for the AT cooler lines, and replace one hose that was too short to reach the new inlet. Barbs were cheap, and I sealed them with tape and locktite.
Pics!
Why is the Mishimoto better? Look at the core size! It also has much wider fins if you know what I mean, which should let more air into the engine bay to cool things.
Nice work....your temps look to be about the same as mine on cruise.....however at the lights I'm lucky if I see 88. If I start getting up it I get to about 82-84.
It's a good rad aye!!!
Yeah, but you got your fans set to 86 or something don't you?
My stockies kick in @ 98!
It is nice. I had to take preventative measures to make sure that the condensor wasn't touching/rubbing, and one locating pin was about 3cm out of line. Dr Dremmel saw to that!
unfortunatly no moar powers in a radiator :(
No more powers but a track day won't see you overheating. Even my old mitsi Chinese copy rad held a perfect 80-82 at Wakefield!
We are do a Wakefield day btw....nationals iin November for CSS! I'll be there wings and all!
Nice work Alex, the car just keeps getting better!
It's gonna look sweeeeeet!
Edited by Daleo
Just a quick note to say that Uprev have now cracked the Cooling fan codes, and I am now able to determine the temp that the thermos come on. They must have heard I changed my radiator.
I love these guys....
:wub:
Question is - what temp do I set it at? I was thinking high 80s maybe early 90s. Stock is 100 degrees.
Edited by PN-Mad
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
