Well, all went well today, car was retuned by DVS JEZ, produced more power, on a safer tune, with great increases in the mid range.
I'm well rooted after today, was a long one, so I'll make a detailed post tomorrow with a graph.
Many thanks go to Jez, and Craig for their patience and knowledge today to get things working together. I think Craig might have got some video, so maybe he'll post that later.
Well done Alex waiting with baited breath on results, also I'm thinking going back to the creek on Wednesday I know I can do better.:)
Nice Alex, where is the graph? I want to see where the boost kicks in...
Boost kicks in extremely early. The thing wanted to keep jumping to 3rd gear when under 40kph so i had to start the run at 50 which in 4th is already on boost
Ok, so here is my account of the day!
Jetwreck and I arrived pretty early after both being RBT'd (with no problems) at the start of the F3. Met up with Jez up the Central Coast. Jez took a quick look over the car and did the fluids, and we had a chat as to what we wanted to achieve for the day, and the order in which we should proceed.
Strapped the car down and ran it up with the tune it drove in on. Car produced a 2kw difference to what I had seen at Unigroup. Jez noted that he thought he heard a bit of rattle, and when we looked at the AFR it was quite lean throughout the range. First change was to try this Plenum Spacer out- a Motordyne 5/16ths that reportedly gives good gains on both NA and FI VQ motors. So as Jetwreck went for bacon and egg rolls, I had the top plenum off and spacer on and installed as per instructions. Ran the car up with the same tune, same temp etc etc and had a loss of power in both the mid range and the top range.
See the Initial green graph compared to the blue graph with the plenum spacer in. So thats a Fail. Its going to be For Sale! It should provide good gains to NA cars- as proven by Motordyne, because they work under vacuum, Air will always travel the path of least resistance, so being pressured, there really isnt a difference between the cylinders that this would compensate for, where a NA car would benefit.
So, back out the spacer comes and onto tuning. I popped the Uprev GT MAF into the car, and flashed the map to the car with their MAF scale. Car ran like shit. So no, Uprev, its not a drop in and click process. We worked to get the car to idle, redid the target AFR and fuel comp maps. to make it run nice. Then we wound in 6.0psi of boost. We spent a lot of time messing around with intake cam advance to try and lower the torque within safe limits. In the process of that we made some pretty big holes in the map here and there, and didn't really see any process. This was very time consuming (as its not a live tuning feature) and I thank Jez for keeping on going to make a good result. We ended up going for the stock map cam advance for the Rev range, but reducing the degrees of advance though the midrange to limit torque. The fuel at this stage was a good 1 to 1.5 points richer than the drive in map, and provided a good safe basis for timing to be worked out. We then spent a bit of time on the timing maps, adding lots of timing to the idle, which ended up much smoother, and adding a bit of timing up top within safe limits.
Things we found out- the ECU is very picky on what intake and coolant temperatures it sees. Unfortunately there is no way to adjust this with Uprev at the moment. The difference can be 2 or 3 degrees of timing that it takes out even at moderate temps (way below the stock fan cut in). Intake cams are a dark art- very hard to get right, reducing the torque while not effecting the power. The best way to ramp the car up is to come in at part throttle, and feed it on through the midrange. This not only reduces the torque load at very low RPM (because it will run full boost in 4th at 2500rpm), but also helps the car retain ign advance up high. It is very hard to measure and tune torque with the auto tranny.
We pulled over 50 power runs for the day, the engine held its temp, didn't misfire or hiccup and produced good safe power without any knock. There we no rods on the ground at the end of the day!
So gains- we went from 4psi to 6 psi dropping to 5.4psi in the top end. We gained 20 to 25 kw right through the midrange, on safer AFRs. Up top we gained about 14kw in the top end where power tips over at 6000rpm. There is no need to go higher. Torque ranges from 470nm to about 380nm - we had a gain of around 100nm.
Again, I'd like to thank Jez for his time and energy in tuning what is not an easy set up to tune. He has researched these motors, and got his head around the software very quickly. It's great that Jez now knows that his dyno is calibrated, and he has the ability to tune V35's, 350z, 370z, R35 and various other Nissan cars with Uprev.
Finally, I have no idea how the guys in the States are producing 400whp with these setups. I can't explain it from everything that I have seen here. All I can think of is some very imaginative dyno compensations, or ramp speeds. I'll be sending some more emails asking questions, but these guys just don't give any info out, and are very cagey. My car drives great - midrange and pick up is awesome, it certainly is a very nice street car.
TL;DR
I got more power - DVS JEZ tunes awesome
Nice graph Alex, Why did you stop there? I would have thought 250kw would have been ok... Do you still have plans for an engine build down the track? You hit the nail on the head with the temp sensors, they affect the stock ecu heavily, and not just engine sensors, the gearbox plays funny buggers too. Unfortunately we need them, if only we could change the sensitivity...
Jez, can you imagine what the kick down to 2nd or 3rd on mine is like? My car needs to be doing over 70-80kph before you ease the throttle on. I hope you have a good strapping system. :)
Torque was the main limiting factor Scotty. Seeing it run 470nm @ 2000 RPM wasn't nice....All it needs is a little load, and that turbos spooling! I think I need to look into it and figure out if it is a product of the converter locking up and producing more NM during that process, or if the figure is correct. After about 2500rpm, torque started to drop off to better levels around 380-400nm
We didn't find the Box make that much of a difference with temp, but then again, I have already fiddled the figures with the Torque management(line pressure) table.
As far as building an engine- if I can avoid it, I will. I'm looking at investing a bit of coin into a different automotive direction, so don't really want to spend all that much on a new motor. However if it poos itself, then I'll look at that path :ph34r:
Sure do buddy. Ran up a 385kw supercharged v8 strapped it down hard and it hardly moved.
Do u normally run ur car in 3rd on the dyno Scotty?
I cant see how a VQ35 with 10.3:1 comp can make big power with a turbo kit on 98 octane. The fuel is definately the limiting factor on this engine.
I used to, as the speed cut would kick in too early to tune in 4th. Now I have to use 4th as the converter lockup clutch slips badly in 3rd and flares up to the stall converter. There was little difference in power but the torque was much higher in 3rd obviously, over 1200nm, which would possibly snap nylon straps imo when it kicked down violently. ;)
True, I just assume everyone has got on the e85 wagon by now. lol.
You mean you haven't yet Alex? :unsure:
Haha nice. We did a run in 3rd with Alex's car. Made 206kw and more power everywhere
Remember his car has 3.5:1 diffs like mine does now. I used to have 3.0:1's which made it more like his 4th I guess. Why Nissan put such long ratios in I have no idea.
Good write up Alex. This information will be extremely helpful to other PNM owners considering the FI/Uprev path.
As different as the ECUs are between PNM35 & NM35, there are an awful lot of similarities too.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
