would there be any performance or temp difference (whether increase or decrease) from swapping from a generic hybrid style core to a R33 GTR core?
those generic bar and plate coolers are very average once you start to up the boost. 17-18 on they heat soak real bad.
Yeah it really depends.
Some generic stuff is fine, and some other makes/upgrade kits are using china cores for 400rwkw+ applications.
So gotta test pre/post boost drop etc.
interesting, thanks for the info guys.
i will get my tuner to check for heatsoak when it gets tuned next week.
Status,
do you want to expand on why the r34 core is superior to the earlier intercoolers :yes:
someone correct me if im wrong! Though, 32 and 33 are the same, the34 only differance is it has Temp sensors attached.
Im still tryign to decide on this 32 GTR cooler for my GTS4 rb26.
cores are differrent. but them side by side you will see.
  • 10 months later...
we gained about 20kw switching from a standard 34 GTR cooler to a thicker 100mm unit on my brothers car, which has a 6262 on e85
although the power increase was also a result of another 4-5 psi of boost but our tuner said a thicker cooler was required to utilise the boost
jumped from 420 to 440kw.
and in terms of standard rubber piping... mine keeps tearing with -9s on e85.. I've had to replace the rubber pipe just below the twin turbo pipe 3 times now. Have a hard pipe kit waiting to go in. The rubber ones are 17 years old now and struggle with 25psi running through them.
Edited by usmair
seen a R34 blow the ends of the core as there not welded like they are on a 32/33
there like radiator end tanks style which didn't seem to like big boost only running n1 turbos or smoething
car only had low 300kw to did it on the track end up cutting the little flaps of the tanks and welding them on
Well that's nothing to do with the cooler really - just shows how good the GTR core really is if you screwed in 6psi for only 20rwkw after you went to a 100mm item, which is pretty average really (only 20rwkw for 6psi).
You'd sooner back off the 6psi and live with 20rwkw less and enjoy the much safer setup.
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
