No call yet, I'll go to my local cop shop if I haven't heard anything by next week and look into pressing charges so the cocksucker loses his job
you got rammed by the truck or something yeh?
thats f**ked
Cops didn't tell me the name of the company and I only got the rego, couldn't make out the company name on the door as it was only small and the rest of the truck and trailer was plain white...
All I know is it's a company in the sticks...Druin or something?
Never really heard of the place, but I guess if it's small enough it wouldn't be too hard to track the company down. If I can do that then I'll definitely call but I wouldn't expect some freight company in the sticks to have a HR department..
http://www.truelocal.com.au/find/freight-transport/vic/gippsland/drouin/
If it's any of those I'd say it'd be 1 of the first 2, wasn't a cattle truck and wasn't a flat bed which would more than likely be the trailer choice of a crane delivery company...
The fact that they're businesses in bumf**k nowhere means they have no websites (that I could find anyway) so no chance of seeing a picture of their trucks/logos
Do you know the guys name? Will be easy to confirm the company he works for.
I.e. If it's company number 1.
Get someone to call up 'Can I speak to John Sanders' please?. If yes hang up.
Call back in 5 mins. Speak to HR, if there is none, speak to the Directors/Bosses or managers.
Touche'
But thought you chased the truck till he stopped so woulda thought you'd ask to see his licence to get his details etc..
Or did you just pull over after it happened cuz your car was busted lol?
Touche'
My car was fine...I pulled off the exit ramp coz it looked like he had finally come to his senses and was pulling over, as I did that he went straight through the lights and back onto the freeway..I was already on the phone to the cops by then
If I did get him to stop, I wouldn't have been asking to see his license, I would've taken it out of his pocket after I KO'd the flamin mongrel though.
Seriously can't even begin to describe how angry I was... and that's without steroids.
what car were you in?
My EA...Bull bar on tow bar is the only reason there's no damage...Haven't checked if the bull bar has been pushed in or whatever, doubt it but that'd be the only damage if there was any.
My brother has been talking to a cop mate of his, makes me wanna fucking smash that cunt of a cop as well...They're all stupid cunts
'Is there any damage to your brothers car? If not they must not have collided. Obviously at speed there would be evidence of a collision, paint etc'
So basically you're allowed to go out and ram whoever the f**k you want, just don't do it hard enough to cause any damage or leave any paint and your in the clear. Or slap on an unpainted bull bar, smack a car with a tow bar and you're set.
