Just got home from Winton.
It was just a lovely trackday. Drive home was bit boring until I got off Hume at Seymour and went to Yea, Kinglake West, Whittlsea then home - enjoyed the drive even though the R needs coilovers, camber arms, swaybars, decent wheels and tyres though.
Weather was weird in the morning, arvo is fine. Re-burnt my arms.
