Just got home from Winton.
It was just a lovely trackday. Drive home was bit boring until I got off Hume at Seymour and went to Yea, Kinglake West, Whittlsea then home - enjoyed the drive even though the R needs coilovers, camber arms, swaybars, decent wheels and tyres though.
Weather was weird in the morning, arvo is fine. Re-burnt my arms.
Whttime did u leave?!
BP car meet is still on. So see you tomorrow Strawberry kisses I mean orange kisses :P
I would enter the SnS if you could leave early. But probably won't enter as you cannot leave early.
leave where early? what drugs are you on bro? lol
i can get to BP whenever. and can leave SNS early.. im not entering as i think its a bit pointless staying there for 8+ hours. especially when i know i wont win anything.
Fk entering trophies are for poofs
lol that and i'de rather the freedom of driving my car home
