20 years doesn't mean 20 years to develop a more powerful engine, there's more to it than that. Any manufacturer, even Daihatsu could put a 220kw N/A 2 litre engine in the thing if they really wanted to, but it means more money on production costs and less fuel efficiency. But try passing in the RB20DET under today's emission standards and you would be laughed at!
And for that matter, 20 years prior to the R32 GTS-T was the TA22 GT which weighed in at around 900kg and made 93kw from a 1.6 litre N/A engine...
I think you'll find this car to be positioned with similar performance to other sports cars within similar price ranges. They may also be making space for more powerful versions of the engine down the track, giving marketing something to keep pushing the product.
I know an rb20 would pass emissions the s15 in 1999 didn't even pass American emission standards hense why they never got it
I just expect a 'sports' car to have a little more power
really just depends on the price if the ft86 is around $30k for the na model as people have been quoting then, it will be decent but if it's closer to $60k, I don't see why you wouldnt just spring for a 370z or skyline v series
im a limo driver tomorrow daytime for stakes day or whatever it is.. gonna be cruising around in a 300c lol.
sat night im free though.. pm me your number and i'll cruise up with you if Ive got time.
I was more asking where are you taking the Stagea boys this weekend don't you have a cruise on?
Your a banker/Audto guy and a limo driver. Shit is full on bro
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
