Strictly speaking a wat is a Buddhist sacred precinct with monks' quarters, the temple proper, an edifice housing a large image of Buddha, and a structure for lessons.
The Internet, use it.
You guys make my head hurt.
People cheering and lobbying for superannuation contributions to go from 9 to 12%. Little do they know that businesses will wear the cost it its likely to be offset by a wage decrease :/
Smoke and mirrors boys
Chick going round job sites offering special paint ball deals for tradies. my god she was mint was starin at her face day dreamin while she spent like 10mins explaining shit :/
Yeah I can imagine, you imagining doing all forms of your own paint balling to her face :D
they have good lookin wimminz so you buy their shit/services to one day hope to see her again.
Two different blokes came around offering that deal at work.. pitty i didn't get the birdies :(
lol dirty kunts
Was a good deal though $300+ worth for $79
I wasnt interested in no paint ball just wanted to keep her around for a bit ^^,
shouldve asked her in to see your paint ball gun hahahahaahha
Do you have a phone? Where are the pics?
Isn't this always the case?
Worker: I want greater benefits
Government: We are not going to pay
Business: We cannot pay
Worker: I won't vote for government unless I get greater benefits
Government: Business you must it is law
Business: We can't wear the cost, we will pass it on
Government: As long as that is ok with Worker
Worker: I still get the greater benefits though right?
Correcto.
If a business can only afford to spend $100,000 on wages it would be:
Before:
$91,743 as a Wage
$8,257 as Superannuation
After:
$89,286 as a Wage
$10,714 as Superannuation
So suffer now so you can enjoy the extra money when your 60 :D
your a peverted man. why would he shoot off a load, it would be rounds of paintballs. nothing suss
That's what I meant. Loads of paintballs. Where's your head at brudda?
Took a year but I just got an apprenticeship with a big company. Probably could've gotten one in domestic straight away but f**k working for $300 a week, before tax...
I'm thinking of going to grab whatever comes first, cbf waiting for 'perfect' one simply cos I really hate my current job.
Would happily sell the GTR though.
My question is would I get the job I want after completing the course (which is 3 weeks away), cos was told 50% of pre-apprentices have successful landed an apprenticeship.
Also told many plumbers doesn't like apprentices who doesn't have exprience in domestic - if I were to change from industrial/commercial, you'd have trouble getting domestic jobs should you need/want to. Just another thing to consider...
Have yet to write a resume - been slacking to be honest. Need to decide what to put in and what not to, whether to simplify or fancy it up a bit.
Should be fun times ahead for me...
