:laugh:
My mrs offers to pay for pretty much everything pretty much all of the time, and she doesn't do it as an empty gesture. I still pay for most stuff (dinners/movies etc) but usually have to force her to let me pay...She's a keeper :)
exactly the same as my previous situation.
Uni fees would also depend on which Uni you go to.
i.e. Melbourne Uni would be quite a bit more expensive then going to say Deakin Uni I would imagine
yeah i think thats it. Mine were Monash fee's. Im sure Melb uni is a lot more for a lot less info ;)
rmit is cheap too.
I guess you hang around Melb Central with your biatches like a pimp during your breaks?
She'd be rough though i reckon.. I love a rough bitch :)
Would love to wrestle her :wub:
Stop filling my mind with dirty thoughts
:ninja:
