3 mil is the footy show alone, and that was in 2009. In 2011 + Triple M commentary + endorsements + guest speaking roles + investments etc. etc. he would be closer to 5 mil a year IMO.
Lambo is chump change at that. Even on 3 mil it might be a quarter of your salary, but who needs more than 2.3 mil a year to pay for living expenses and luxuries...he's always been keen into cars too.
dont see why 700k would worry him considering he's been in tv for quite a while most of which he's been in headlines = even more money
should see his boat...
no boat compares to 50 cents porsche designed yacht things fkn insane
cant find any pics of it
he doesnt do radio anymore got sacked in 09/10 whatever it was
Did not know this, oh well, he's had a lot of years under his belt as a millionaire - the first is the hardest.
Is it better than that yacht owned by that oil tycoon who owns/owned Chelsea FC?
Abromovichs navy google it if your not familiar 4 super yachts his latest is largest private vessel in the world has it's own sub marine and missle defense system bullet proof glass in main bedroom etc it's ridiculous!
At what point do they stop calling it a yacht and consider it a ship? Or an island?
The super wealthy head to the water and the skies lol. You see Fezzas rocking Chapel St and you think wealthy, but them when you hit the waters it's a whole different ball game.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
