That dirt bikes similar to what im looking for.. still not sure if i want the full motox version or trail spec yet
When we going on SAU vic road bike ride?
Give me a week or two to get acquainted with my ride and we'll go for a ride. Charlie needs to get another road bike and she can join us...
All that happened was a few Americans ripped off the Jap VIP from the '80s, Westernised it, profited massively.
And now the "trend kiddies" or "band wagoners" have their knickers in a knot over someone else profiting...
Absolutely hilarious.
Still haven't read the thread, cause I can't be bothered reading anything to do with "stance", but are they complaining about the new people who will see their trend and then copy it off them? Doesn't this happen just by driving on the roads to show off their "stance"? Morons.
Nice, how does the RX-8 drive?
Always liked the interior, from what I remember from sitting in one at the Melbourne Motor show many moons ago :D
its not a 'powerful' car, but its enough for her..
drives really well and revs out to 8500 factory...
interior is awesome, with the recaro buckets as well..
she loves it
inb4 Mohsen tries to get a work exemption for an R1, then sells it to buy a spate of shitty bikes and is convinced they're broken all the time, all the while spending good money on pointless mods and acting paranoid about the police defecting his standard 250cc learner bike
fkn lol, but fyp brah
lmfao ric.
not helping charlie!
Srsly dude, the license test isn't hard... if anything the longer you leave it the more bothersome and costly the process will become, recently there have been articles on how the tests aren't strict enough etc. Plus it's not as if you need to buy a bike straight away. Just get your license to begin with!
Two things that usually kill people on bikes, being their own stupidity/inexperience or other drivers on the road. The latter can't always be avoided but there are certain ways to ride in traffic that improve your chances of surviving :thumbsup:
Hella flush bike.
Don't get me started on speedboats Rimon, lol, father always had them when I was a kid so that could easily come back into my life and I don't need any more expenses. Jet skis are pretty f**king awesome though...anything can tow them, buy a POS Commy or R31 for a grand.
Korean bike, not the best quality but have come a long way and look awesome, especially for the dollars. Would be perfectly suitable for a bike on your restrictions, probably what I would get if I did it again. Don't sound half bad either.
-_- That's why I was referring to the Suzuki and not the R1 with that particular change, I agree that chrome would not match the R1, which is why I said rim tape.
You wouldn't bother colouring the rim on something that's not a show bike because in all likeliness your rims are going to be scratched up by the mechanic at the shop next time the tyres are changed. This obviously doesn't matter with polished rims because there's nothing to scratch off but painting something is just going to mean you either need to not ride the thing, change the tyres yourself or be prepared for a redo every time you change the rubber.
oic. I am much confuse.
Women speak in riddles at the best of times ^^^ much better explaination
:D
Seriously though if the tyres can't be changed without scratching rims... Or a properly prepped/painted setup that will last against track work... Surely possible?
Can be done with car rims. Can't see it being much different
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
