I wouldn't at my age but I might be open to it when I'm older / settling down a bit. depends on my partner too currently i'm foreveralone.jpg
Some kids are awesome, some kids scare me lol
and yes birds is unaware :P
another dead biker on nepean hwy this morning apparently in his 20's :/
so many of em out today the more i see the more i wish i was out on mine! fml
also pretty cool doco last night on national geo channel bout riding gear/helmets/brakes etc and how they're made and tested. shame only caught a bit of it..
/bikes
/bikes
Couple in their 60's...blind motherf**kers. Scares the shit out of me that one slip up like this could end my life :(
This is why I ride through the mountains, if I lose my life there it's most likely going to be my fault and not the stupid traffic mistake of someone who is too old to be held accountable anyway.
i'm sure the younger biker will no doubt be blamed for it most likely coz of his speed or some bullshit. any excuse to come up with another dumb ass "wipe off 5" ad instead of pointing the finger at people who don't know road rules.
should re test all people over 50 years of age i bet most of em will fail
Yeah, problem with blame is, whoever gets the finger pointing in the end, that guy is still dead. People don't realise how life affecting their decisions on the road can be, don't think they ever will until something bad happens to them. It's like the road is a theme park ride and the worst that can happen is a bump from a dodgem car.
On the topic of blame, we commonly drive through green lights at intersections / walk across pedestrian crossings without looking to make sure the cars intersecting have stopped, simply because we know we have right of way and depend on this way too much. Meanwhile, some tool running a red light could kill you and being in the right won't save your life. Sort of similar to the advice that girls shouldn't dress too provocatively to discourage being sexually attacked...you have every right to dress how you want, but you also have every right to walk into a lion's den carrying 2kg of rump steak...doesn't mean it's a good idea. Which is why you should never let your guard down when riding a bike - everyone is out to kill you.
Should re-test everyone of all ages, I bet most of them would fail.
/jaded
its a 4g63 easy to tell by the head
That's what I thought, but 7 Tune posted it and think it's a 4A-GE or more so questioned it...
I was just making sure.
You can tell it' s a 4G63 from the cam covers as well.
Should have kept your EVO Nick and done this :D
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
