Don't go crazy
Apparently some severe rain coming though today/tonight
Come at me weather
Yeh meant to be 50mm of rain today. f**k that I'm not driving today
Pussy, I'll be ripping up Mountain Highway on my bike...
...next weekend when it's sunny.
Lol someone else is frustrating them now asking about specs on an s15.. And they all got frustrated again lol
Yeah something like, "What's a good looking 18" wheel?"
It's like, OP chooses a wheel they like, they get haters, hating on them.
So when OP asks, what wheels do you like or look good? Haters say, make up your own mind, it's your car.
Lost cases.
I don't get it
Nah coils aren't going in today tony. Probably next week or something. I can afford tyres and stuff now.
Tyreshops keep telling me 205 40 is too much stretch on a 8". what is this... Thats nothing. LOL
And I was about to go 195 50...
Take it to Tyrepower North Melbourne, they should help you out.
Ok what about an intercooler?
Is it needed?
Not needed cause the intake charge doesn't get hot enough to see significant gains and the roots style blowers sit atop the engine anyway, directly feeding the intake manifold, so there's no real room. But people have run them before on centrifugal supercharger setups.
