Don't go crazy
Apparently some severe rain coming though today/tonight
Come at me weather
Yeh meant to be 50mm of rain today. f**k that I'm not driving today
Pussy, I'll be ripping up Mountain Highway on my bike...
...next weekend when it's sunny.
Lol someone else is frustrating them now asking about specs on an s15.. And they all got frustrated again lol
Yeah something like, "What's a good looking 18" wheel?"
It's like, OP chooses a wheel they like, they get haters, hating on them.
So when OP asks, what wheels do you like or look good? Haters say, make up your own mind, it's your car.
Lost cases.
I don't get it
Nah coils aren't going in today tony. Probably next week or something. I can afford tyres and stuff now.
Tyreshops keep telling me 205 40 is too much stretch on a 8". what is this... Thats nothing. LOL
And I was about to go 195 50...
Take it to Tyrepower North Melbourne, they should help you out.
Ok what about an intercooler?
Is it needed?
Not needed cause the intake charge doesn't get hot enough to see significant gains and the roots style blowers sit atop the engine anyway, directly feeding the intake manifold, so there's no real room. But people have run them before on centrifugal supercharger setups.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
