no, just trying to make it better than what you can
which is easy mind you :P
bitch please. im building this so i can walk back to it every day and go fuarkkkkkk. meshies make me go fuarrrrkk so eadc
haha I run meshies fag, however even if you do go meshies your looking at shit ones
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
