Get some stroke lol
you mad coz it sounds like a screaming feza!
Anyone excited for Batman the Dark Knight rises?
I might book some tickets when I get home for tonight if there's any seats left :/
watching it tomorrow
hanging for the expendables 2. epic cast
some flamin mongrel stole my bike, f**kn hell.
unlucky brah. i'd get in a car and drive around the area it was stolen scum most likely going for a joy ride
Yeah buddy, expendables 2 is going to be insane.
Unlucky Leigh, at least you had insurance
Shit just got serious
You reported it stolen before the armed robery right lol? Just saves you from suspicion from the cops point of view
Lol yeah I did - they hadn't done the paperwork yet and were about to go knocking on my door luckily the person I reported it stolen to was still working / listening in on the radio and thought "f**k that's the bike!"
lol did they say where?
Bayswater, no idea what store / they took though, and the cops haven't caught them yet.. hopefully they do so I can see the little f**ker and make him pay for any damage.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
