Will have to organise another one some time down the track
Your house or Alvin's?
Cheers for the sausage sizzle and drink!
I'm not very good with faces so always need a reminder :/
Love you too brah
Why my house. Me got no wagyu
alvins.
I want a hit of this Wagyu he's been on about.
Totally mexican. Thats why when coilovers arrive, will need you to flare + roll those guards yo.
no worries.
let me do it before you lower the car though, its a pain when the car is too low and ill need to undo the bottom of the shock for it to work.
you and jono can come this saturday and ill do you both at once.
:3some:
Edited by Sunkist
alvins.
no worries.
:3some:
Be in baw baw this weekend.
Can i pay in wagyu? Lolol
Okay :(
how many guards do you want rolled and/or flared.
it all depends on how long it'll take.. but im not gonna sting you with a stupid price dude. wastelander special.
fronts just take longer because the caliper has to come off(or i prefer it to come off - more room)
Edited by Sunkist
Spent 70 ish on fuel. Will have a few hun tmr, but yeh. Fairly broke now.
Might have some coins somewhere in the car but those dont count
Lol and spent 400 on the whole wagyu lot, spent 270 on dinner on sat, spent lots this weekend
lol is $35 of that from the money I gave you lastnight? So when you pulled up you had $4 to your name?
lol
Looks like 98% of his income is directed at his appetite for waygu
LOL
$400 on beef?
are you of the retard?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
