Tony!
When should I be expecting to get my forum access? it's been exactly 10days and still counting. :rolleyes:
Yeh toby, when's mine gonna be fixed. Tell ash to get off his ass!
Yeah that's up to Ash, gonna have to take it up with him brah
Out of my control
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
