i just had the most pointless arguement with autoxcess in Coburg.
for some reason he thought I was being rude?
i needed new remotes for the varex, and they sent me the control box with no remotes.
so i called him to let him know and he said thats what i asked for? I dont know why I would ask for a control box when I needed remotes.
any way I said its fine, its a $40 difference, and if I had to send it back i'd have to post it coz of work hours. I told him if he could just send the remotes it'll be cool.
nah, guy f**kin lost it lol and i told him we are going around in circles with who said what, it doesnt matter 'whatever' just send the remote.
irish accent - "dont fookin wah-eva mee maet. doon cole mee on a fridee bee-in a smar-ass"
i started laughing in disbelief and said what? I'm trying to help you. and he hung up lol.
so i called him back and said, did you hang up? and he goes nah ill send the remotes today. and hung up again.
/rant
just thought I should consult the wasteland.
Edit: just noticed i can't fookin spell
Edited by Sunkist
Lol I couldn't care any less, all I wanted was some remotes.. He's probably having an off day.. I've dealt with him plenty of times and hes pretty good.
Just today I didn't know what was happening lol
Probably just has his period
77 days of leave payout... I need to take more time off :D
Lol surprised your work didn't try and force you to take some annual leave
turns out BC ER's dont clear my rear wheels =/
prob going to need to run spacers / roll guards
It doesn't clear? Are the springs thick or something?
Run at least 10mm spacers.
And why haven't I seen this thing around, I've been home for 3 weeks and not a sight of it!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
