Tried going in a servo with helmet on coz cbf taking gear off just for few seconds, soon as door opens kunt out of nowhere yells out "stop right there remove your helmet please!"
Thought I was gonna get shot down..
Chill brah
Wear a burqa, that's fine
He was more scared when you took the helmet off, wasn't he?
yes Riq
you weren't aware.... of something that has stickered on the window of every bank and most service stations in austraila for the last 30+ years?
i haven't been around for 30+ years. sorry
yeah it's f**ked
thats problem i have =/
Shieeeeeeeeeet that's not good...
http://www.metalspinnersaust.com.au/metal-spun-wheels.html
Take it to that joint, and see what they say. They could probably remove the clear for you, polish, re clear. Or they'll just make you another lip. Lol.
Not sure on price. Give em a call.
Chill brah
only because you're a unit, they still let me in the shop with helmet on :(
http://www.metalspin...pun-wheels.html
Better off going to an independent metal polishers and just have them polished (cheaper usually)
Has a better shine because the clear will hold back some of it, and there is always a chance to have it peel again
sweet thank you man, was looking for that site earlier and couldn't remember what they were called!
yeah ill have to have a look around - i know there is one guy who told me he does complete restoration for 400$ per wheel.. so if i cant find cheaper i can always keep that in mind..
Id prefer the clear on it to be honest, i think its too shiny without it on those wheels imo
lol probably been robbed by a helmeted dude before...
Just peel it all off and re-clear coat it?
good tattoo
thinking of getting a tatt on same area. working on a "design"
lol id swap for that!
my old man has a detomaso pantera gts but he lives in syd.. i live in melb, see it like once every 5 years as he keeps it in storage
he got it for just over 10K in the early 80s and it had water in the diff and transmission..
Edited by bluejeans
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
