Ahh lol at all the posts on the facebook Hardtuned event.
Got a whole bunch of posts supporting the hektik drifts and burnouts etc and that people should stop complaining about them and that's what the cars are meant for etc...
Congrats Leigh! Now u can get another bike..
Inb4 dezz "buy my bike"
Link?
Link?
http://www.facebook.com/events/347483815341759/350594211697386/?notif_t=plan_mall_activity
Got the job @ cat just need to pass medical test :D
New motorbike..
Good work. It appears you don't have a problem getting jobs brah. Usually can be pretty tough
Cheers guys! Toby I like to think I dominate interviews :P
I just washed my car (well rinsed..), it gonna rain? :(
well rain has stopped here and the suns out again.. lol dumb melbourne weather!
i do realise lawnmowers don't have clutches... it was just the least powered thing i could think of without resorting to jonoe's car
LOL Jonoe burn
not a chance... moh is gonna be done soon
also moh spends more than 3 weeks a year in aust
Classics always take ages, my old man's 57 Chev has been in panelshop for 3-4 years until a few weeks ago
Those kind of resto's are always pushed to the side for quick money work
Congrats to you Leigh, more money = more power now yeah?
Mmmm just made a bowl of wonton soup from missus' homemade wontons = WIN
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
