haha Nick maybe an intercooler or exhaust down the track probably not for a while though, new bike is first priority! and after being unemployed for around 3 months gotta re save some cash first!
Birds, prob best bang for buck r6 i've found
http://www.bikepoint...id=139F3FE2A257
http://www.bikepoint.com.au/all-bikes/private/details.aspx?R=13277674&__Qpb=1&Cr=10&__Ns=p_PriceSort_Decimal%7c0%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0&__N=1432%20604%201430%201429%201626%201428%204294967267%204294967096%2082&silo=1400&__No=15&seot=1&__Nne=15&trecs=39&__sid=139F3FE2A257
this one nice too, however those KMs look suss considering the amount of work done?
Can't believe R6 prices when equivalent year and mileage R1s are only advertised at ~$1000 more...I couldn't buy one knowing that. Keep waiting for a real bargain or get an older R1 IMO.
I like the slightly lighter bikes, r6 still has 120-130hp although upon researching a little bit cbr600rr is meant to be a better bike little less power but doesn't rev as high(105hp), only weighs 154kg dry too which is less than r6
edit: cbr don't look as good for the 2007-09 ish ones, hate that dash on it too.. no cheaper than r6s either
I was looking at small bikes for a girl I'm seeing and am amazed at some of the weights. Thought my old Virago was light at 138kg - CBR125 = 115ish and Megelli 250R = 112.
/subtle
/subtle
Cliffs on girl please. Sms is ok
Which XR6 turbo? After all the hype about them, I was quite disappointed when I drove a standard BA...granted it had no air filter; air straight off the turbo LOL
You've seen her I think? The one who asked me out.
Yep...was thinking about swapping to third party, but with the way I ride, I may need the comp one day.
3 regos
2 full comps
fml
At one point I had three rego's and three comp. insurances. Man that was an expensive year.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
