man vs food...
burrito chalange (in knoxville)
burrito:
2 lbs pulled pork (900g)
1 lbs beans (450g)
1 lbs coleslaw (450g)
1/2 lbs cheese (220g)
4 full size tortilla
sides:
1/2 lbs mac'n'cheese (220g)
1/2 lbs bananna pudding (220g)
1 hour
that's a total of just over 5lbs (2.25kg)
never before complete (adam richmond was aparently the first to manage)
how ya reckon ya'd go dezz?
i reckon i could do it
He only ever beat one burrito challenge, dunno why he can't beat them. Especially considering sometimes the food comes to 3-4kg and he eats it
acland cellars brah.... 600 beers
yeah these guys are good
What do people think of wrx? I inspected one for a friend yesterday and was actually quite impressed and are in the same price range for an evo. What u dream boats think
evo
wrx is basically an underpowered evo with a weaker gearbox and higher percentage of cars with mini boxing gloves hanging from the rear view mirror
Yeah I myself would choose evo, even went in a mates sti and found the evo to be a bit more fun
wogs
*lebos
Sigh my reply I typed as I was walking into work hours ago didn't send due to me walking to area of no reception zzzz.
Second hand knowledge only but evo > STi
But the suby apparently is/can be a bit more daily friendly, with few things like cruise control, but more low down torque with the extra displacement and what not.
I'd be interested in the insurance difference though, since import v local ? Anyone know?
Edited by kaitoukid
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
