Let's have a toast for the douchebags
Let's have a toast for the assholes
Let's have a toast for the scumbags
Every one of them that I know
Let's have a toast to the jerkoffs
That'll never take work off
hilltop hoods live stream if anyone cares? lol
http://www.ustream.t...den-era-records
edit: audio problems, theyll be back in 3 mins lol
Quick Hamish, get on it!
I think the reason I don't find Evo front ends attractive is the headlights...are there aftermarket versions available? Something blacker / less shiny and clustered looking?
Is 'he' you Birds?
Close, but you're way off!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
