Who wants to install a turbo timer. Ill pay u
Even if its plug and play. I have Nfi
Don't bother with turbo timer, just drive slow for 2 mins beforehand or idling for 2 mins before turning off
Gotta remember NA's have a niche in p platers, and there is a difference between say a manual coupe and an auto four door...
I think it's clear this is what Aaron's final goal is:
Yeh. That was my thought and the fact all the parts swap out changed my mind from a 8..
To me the 8 looks like a hungry whale.. And the 9 is still to expensive.
Over all I preferred the 7 front bar over both.. And 230kw was a comfortable goal which would seem to be a safe daily.
Well I picked mine up for $17750. With rwc and 1 year rego.
Everything else is still listed for $22+...minus RWC
Insurance has agreed value for 22k
I think I won.. especially when red book still has them for 20 average
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
