Night rides are much nicer imo
Shame you can't get too comfortable with all the idiots driving around
I love riding at night. It's in some ways safer too, what with lights and shit...but also more likely to come across drunk drivers or people assuming there's no one else on the road.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
