Ahaha, not to worry about that, my future list of planned mods (*cough wish list cough*) is WELL under construction :thumbsup:. Moar powah indeed.
I think stock is usually closer to 160awkw from what I've seen though. But still good gains for $in for sure.
Have been lurking many threads :P
Can't wait.
Still a long wait to go though, haha. *continues the dream*
Edit: Also how's the steak shop coming along? Feeling like a steak soon... when do you guys open? :P
Edited by kaitoukid
I was out there earlier actually. Looks like a restaurant now, plaster is almost finished around the place so rest of the fitout should be done in 2-3 weeks.
Hope to open end of Jan and then be in full swing by mid/late Feb (won't open to capacity right away). Liquor License won't be ready till Feb anyway so it'll all fall into place nicely
brought a pioneer vsx-527-k, great a/v reciever, very cheap, 397, but took it back cos the media streaming / internet radio interface was sub ordianry
if you have an old a/v reciever and are keen to upgrade this unit is a bargain at 397. its a shame i wasnt so keen on the streaming/internet radio (even with DLNA)
the interface was clunky, cumbersome and just slow for my usage. back to vsx-522 and media monkey
its all in the gearing and final ratio that makes up for the lag
how else do you make so much power and midrange from a 4cyl 2 litre with a big single
this
with the bigger turbo, my skyline made full boost at 3200 and the evo makes the same at 4000 (dyno - 4th gear) but they both feel close to the same and the evo is a tad more responsive, despite making boost nearly 1000 revs later
Power commander and BMC filter installed.
One step closer.
What's left?
Glad I got mine running today, f'ing thing, wasn't what I wanted to spend the day on.
Damn it sounds good with the aftermarket exhaust though
this
Yeah for every Skyline gear change, EVO is doing about 1.5 gear changes. Such a nice gearbox though, punching 1st to 3rd so seamless
What's left?
Waiting on the o2 sensor eliminator, and the replacement indicator wiring adapters to arrive.
Once I've got those I can put it all back together and it should be good to go. Gotta get down to Vicroads and get a new plate for it too, cars etc can all be done online but for some reason they make you go into a branch for bikes ffs.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
