And make sure you update it before using it, otherwise it locks and its a pain to reset
I updated after using it and playing around with it... no problems. :rolleyes:
Ted's is expensive... might go to JB HiFi.
Btw, are you using the suction mount to mount it on the gokart or do you have the handle bars mount?
I have a suction mount, currently it's stuck to my bedroom door and I'm using it as a towel hook hahahaha
then 'accidentally' leave the go-pro on, when the missus comes over...
... i c what u did thar aaron
Let me know how much u find the handle bar one for.
Saw it for like 20-30 but not all stores have them, every store has limited of different stock.
Went to 2 JB and 2 HN, none of them have the suction mount..... looked on the system and only HN in Frankston has the suction mount in stock... was looking forward to playing with gopro. :verymad:
oh well, I'll just do some selfies.
I'm not too far from franga maybe I can pick one up for you?
far out
my dad got a panasonic blu ray player and pvr in one
on the box it has plays divx/mkv and records tv
MY f**kING ASS IT DOES
this product is the biggest piece of shit i have ever seen
shitter than the pioneer vsx-527-k
this thing
wont play xvids which is basically the standard these days and the same for mkv as it;s just a container
so essentially out of about 25 movies i copied for him, it only plays 4 that happen to be mp4 mpeg4 format
and it has to be via DLNA so it expects the pc to do the transcoding on the fly
so basically you hit play wait a good minute or two for the transcoding to buffer enough then it plays
WHAT ASS
the WD TD LIVE is absolute god compared to this device
oh and it gets worse
it has USB on the front so if you plug in your own USB drive it has to "register" it and format as linux ext2
so then you cant just copy your own movies to it and play movies off that, played divx movies must be off the network via DLNA
why design it like that
ASS
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
