lol... that probably "exists"
you would be surprised how often costco meat is used in restaurants
Yeh I get told that's the meat is great strangely enough.
Eh. Don't really want to try it..
and btw, i'm happy with 8+ might even be a 7, who the f**k cares.
lol, that's definately 8+ (more like a 9 on that bottom piece)
6 is a LOT less marbled
it's fine... I buy costco meat when i go there... cheap and better quality than coles/safeway but lower than a good butcher.
Generally i buy all my meat/fruit/veg/asiangrocerneeds from the Vic Market these days
I go once a week and spend approx $400 per month less than I used to at safeway, AND get waaaaay better food
yeah i know what you mean, but that was out of a vac pack that said wagyu f1 silver by stockyard, and that means 6-7
tbh i have no idea how they grade it without even being able to look inside.
if you want wagyu.. and i mean real wagyu be prepared to pay for it (think more than double their prices)
also I highly doubt anyone that works there can actually cook a steak properly considering the ones they used for their pics on the website aren't even decent
Well it was about $50 for the wagyu at Meet Wine and Co, should be looking at $100 for quality wagyu? Name and place please Sir!
They have x-ray vision.
my place. just pay for the beep. lol. no sauce, just salt and pepper. eat it and go.
ps, aaron still has some.
i'm guessing it's graded BEFORE it is packaged lol
An easy place to start is Rockpool... brilliant steak that is still decent size can be had for about $70-$90 and make sure you have it with the housemade harrissa - it's fkn epic
if you want true wagyu... as in david blackmores full blood...
the last place I had it was bistro vue and it was about $80-$90 ish for a 180gm rump cap... and it was worth every cent
hmmmm.... My missus birthday is coming up, might head to Rockpool.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
