What kind of rattle? When does it happen; clutch pedal pushed in or clutch pedal out? Or both?
There's a spring that holds the fork in place to prevent vertical movement, but the top of your pivot ball may also be damaged or broken.
Pedal out. Resting my foot on the clutch makes it go away, it only needs a tiny bit of pressure to stop.
Changing the pivot ball is box out isn't it?
Can't see it, need to log in, cbf doing that.
How cheap is the GTI-R?
sorry thought you could see classifieds. $4.5K nego (they bought it with a broken gearbox and fixed it, but didnt register it) "new head gasket, few extra goodies"
not sure if this'll work:
http://forum.pulsar.org.au/attachment.php?attachmentid=51553&d=1361346820
http://forum.pulsar.org.au/attachment.php?attachmentid=51554&d=1361346854
http://forum.pulsar.org.au/attachment.php?attachmentid=51555&d=1361346900
Link no work...
I feel bad for webber... I mean don't get me wrong, I'd change jobs in a split second.... but i do feel bad for him
he is 100% the unluckiest, rediculously lucky guy in the world
Alvin and Tony!
You guys bought your coilpacks from Amayama yet????
Think I need some as my stag just started misfiring/hesitating after about 4k..... it just happens every now and then though, could be coilpacks right guys?
Yeh so he hasn't quit, he is not renewing his contract.
But still, out of F1 altogether, and redbull looking for kimi reikennen(however its spelt)
Lol both would want to be number 1 drivers. I wonder what'll happen lol
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
