relationship advice?
Yep
What happened Matty?
Spoke to her last weekend, said I'm not gonna have any regrets, so just one last time, do you want to try again?
She said No. Had a bit of an argument, got upset, next day thought "f**k you" and started moving on. Today she messaged me about picking up her shit then wanted me to drop it off, I said No. Of course she started an argument over it and resorted to insults, and I didn't. I didn't give two f**k's, I felt nothing anymore, and I loved it.
Add in the fact that I'm seeing a f**kin cute as f**k chick this weekend, 10 times hotter than my ex... yeah, I'm already happy :P
Great to hear mate, it'll only get easier too. Sounds like you got closure from the "no regrets" thing, pushing all the blame onto her.You may have a relapse or two along the way (hopefully not), but stay strong - they will disappear in time and keeping yourself distracted is a great way about it. If you start thinking about her or get the urge to communicate again, just think about all the things that pissed you off about her and how she hurt you during the break up.
Don't fall into the trap of comparing new girls to your ex, as is common after a recent break up and can bring up feelings you don't want. Just have fun and enjoy the good parts of being single. You never know when you'll meet another one worth keeping!
And...it's completely normal to always have a soft spot for someone you once loved...when someone is a huge part of your life for so long, there will always be memories and nostalgia. So don't feel bad about that if it happens.
:cheers:
I'm like 178cm ~90kg and I wear a 52......
... I... I don't know brah. Didn't try 48 since 50 felt pretty damn snug... Could try when I go back but :O
edit: also probably not some ripped unit like you.... yet. (A LONG WAY AWAY "YET") :P
You might be alright mate. I'm snug in a 52 and 187cm, only 80kg. Body shapes and brands vary so much. Just make sure it's tight, but allows you to move around on a bike. Pas had me sit on a bike at Peter Stevens, which you should do to get a feel for if the gear is too restrictive. And remember, it will loosen up over time. You're doing the right thing :thumbsup:
Dezz has huge legs if I recall correctly.
Yep
fuck bitches
get money
Oooh, that's an idea. When I go to make my purchase I might ask if they'll let me do just that :D. Yeah with the loosening up considered, I was edging towards the 50. Also it had the insert liner thingy you could take out for summer, which frees it up a little? Plus my cut continues... maybe factor that in... xD.
Cheers for advice though, liking the sit-on-a-bike-there-with-it idea.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
