Yeah will be fun
Has so many options on it it's crazy, even has a rear passengers side reclining rear seat
I dont know why so many people are finding the rear seats reclining so amazing. the m35 stageas do it lol
Well I've owned a 32, evo and a golf, None of those cars ever had features like that.
Sunkist, on 02 Jun 2013 - 09:17, said:
who'd you buy it through?
Ben @ J-Spec
