Any parts in particular you need or the whole thing? Might be able to get a bloke to go over it.
I'd prefer the whole thing if possible, that way I can double check everything and start ruling out causes etc
What was the damage?
$300, with a 2 month old GT Pumps actuator :D. Done about 70K kms.
Only thing is a snapped bolt which the thread doctor quoted $40 to drill out.
Not bad imo.
Waiting to hear back about some injectors atm as well :P
Not bad imo.
still waiting on that injector guy? thats some slow responding.
Not bad imo.
good price, wouldn't want to pay much more than that
tell me about it, -___-. if it doesn't work out, going to probably go with some id1000's. but dat price tag.
yep! didn't want to spend more than 350, really. but now should hopefully flow 250+
much money, hipster boy
who is this hipster boy you speak of?
yeah same, must've been that odd occurance
I've heard they are planning to build one in Epping now too
Apparently, they're looking at building Costco somewhere on High St or around Epping.
And where Pipeworks is in Cambelfield, that's going to be Ikea opening early next year....
Stance? Probably not. Wouldn't mind being fairly aggressive, though. Wheels are still awhile away... not to mention coilovers as well.
Alvin, why not just go to the new Ringwood one?
Also not sure about those Kando turbos, could swear I've read some evooz thread(s) which do not recommend... Unless I'm thinking of something else.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
