Apparently, they're looking at building Costco somewhere on High St or around Epping.
And where Pipeworks is in Cambelfield, that's going to be Ikea opening early next year....
Yeah was wonder what they were going to build where pipeworks was
The CostCo would have to be near the new Melbourne markets, plenty of land there anyway
Stance? Probably not. Wouldn't mind being fairly aggressive, though. Wheels are still awhile away... not to mention coilovers as well.
Alvin, why not just go to the new Ringwood one?
Also not sure about those Kando turbos, could swear I've read some evooz thread(s) which do not recommend... Unless I'm thinking of something else.
Iirc people run them and they are actually really good, however they say stay away from the td06-20g as they get a lot of compressor surge
Not sure about the new comp covers that have the anti surge comp covers though, already had my 8mr so stopped looking into turbos
i already have dump and front pipe ($100 for both)
licp link blocked at work for some reason
i also have a turbotech lying around but cant find it.... will be either that or a 2nd hand 3port for like $75
hey anyone got any work going?
friend of mine has moved down from cairns. he will do anything (lol) but has been working in hospitality for the last 4 years.
let me know if you have anything guys!
nab collections call centre will be hiring in January through Randstad.
$23.50/h or some shit or $27.50 for night (12-9 shift)
Great way to start banking career... i was there for a few months only before moving on to better jobs
thanks hamish, ill tell him to look into it.
What scotch would you buy for $50 Hamish? Also $100-$200? I'm building a collection and don't know heaps about good scotch (translation: haven't heard any brands mentioned in rap songs)
under $60 go for any of the following: (always quoting dan murphy's prices)
glenlivet 12
Balentines 12
Johnny Walker Black Label
Dimple 15 Year
glenlfiddich 12
Glenrothers reserve
Johnny Walker Double Black Label
Glenmorangie original
not far under $100 go for any of these:
Macallan 12
Ballantynes 17
Glenlivet 15
Glenfarclas 12
Johny Green if you can find it as production stopped in 2012 and it was their only blended malt (I have a bottle for Orlando as it was his birth year)
if buying for a serious whisky drinker also consider:
Lagavulin 16yr (very strong taste - not for a beginner scitch drinker)
Laphroig Quater Cask (same deal as Lagavulin)
Tallisker Distillers edition
If starting out with scotch and not sure, either buy the glenlivet 12 for $45 or Yamazaki 12 for $95
Personally I would recommend the Yamazaki if you want to start a life long addiction that will likely bankrupt you
shit... I read $100 - $200 as around $100...
ok under $200:
Yamazaki 12
Nikka 12
Nikka 17 single malt or blend
Hibiki 17
Highland Park 18
Macallan 18
Glenfarclas 25
Tallisker 18
Caol Ila distillers edition
Johny blue if not only for the bottle (the inch thick glass one)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
