Hahaha going up driveways and flooded roadways are a beautiful thing now. With all bags fully pumped at ~100psi, I give mum's Captiva ground clearance a good run for the money.
Bahahahaha touche sir, touche.
I was considering it, but we all know how much cops LOVE to be right so if they see me low and then when they do pull me over Ip'm at over 100mm, they will search for anything/everything that will prove them right. In this case, a cure is better than prevention :)
My fail-offset rims means driving aired up makes the wheels look even more fail :(
Rather fail offset rims for the time being over a defect though lol
BEEN VEGETARIAN
HAHA
and how does this affect you?
your single handedly causing global warming. by not eating cows which release 85% of the worlds methane. this reflects the suns heat escaping from the atmosphere, which has caused governments to think its co2 emissions, not the earth just going through its usual 20000 year cycle, causing carbon tax, causing our bills to rise, and causing steak prices to go up.
that enough? :woot:
that enough? :woot:
Right, that's why being vegetarian is healthier for the planet; It takes less energy to feed farmland for a vegetarian diet than livestock for a meat diet... raising animals for food produces more greenhouse gas emisssons than all of transport combined.
http://www.chooseveg.com/environment
nope. your eating all the plants, that turn co2 into oxygen.
basically your suffocating us.
Oh, and Pauly, when you coming around for a game and a beer?
soon mate, couple of the boys are coming over thurs to help with the last few bits and pieces on the micra, if you fancy a beer or two at mine? but give me a bit of time mate, and ill head down one weekend, maybe bring the missis and mine and yours can talk babies!
Yeh it can.
SWEET! I've had a look and most places are charging about ~ $200. You able to recommend a place?
Do NOT bring the missus if she is gonna talk babies with my missus!! Again, DO NOT BRING HER!! Hahahaha jokes! Yeah mate, bring the missus. The missus probably has a few thousand hints/tips to give so def bring her :cheers:
http://www.theage.com.au/victoria/langwarrin-hoons-fifteen-minutes-of-fame-turns-to-shame-how-kochie-helped-nab-a-dodgy-driver-20140122-317ji.html
fail lol
i'm actually surprised at the charges... seems being on provate property does not change things?
i'm just curious as to how this differs from a track day?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
