No, I prefer to get irrationally angry at people who get nostalgia about things that are 'silly new things that little kids are into'
Like Pokémon.
How dare this forum autocorrect and add that little thing above the E.
stupid nostalgic forum
Pokemon is the goddamn bomb.
And going strong; this was just announced:
Originals were of course, awesome. I loved GSC too, felt pretty much like the originals to me.
After that is what I started to consider new gens... but I still play each new gen when it comes out, SO GOOD.
youth5eva
por que no los dos ... something something:
ur fav plattsy :ninja:
you know i would have to pick the last one just because its the only one not photoshopped...
stupid new age kids photoshopping everything got no idea of real beauty anymore
then again that all started when bitches started wearing make up...
Speaking of Lego, friend linked me this the other day:
http://www.amazon.com/exec/obidos/ASIN/B00HX14C7Q/ozba0e-20
And yeah, the Death Star in lego always looks impressive.
True dat at expense; yet I saw people had limited edition Millenium Falcons which cost around $600, now going for like $3000 (some guy sold his used set for $2500 lels).
You mean that my falcon is worth a shitload more than what I paid?!
I'm sure you'd bang them all though :P
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
