inb4 3 way rolling drag between leigh, turbo dragon and myself
We're all RWD yeah? We can do standing start, but not much forward movement will be happening for the first 3-5 seconds for anyone though. Will be a great smokeshow though :cheers:
Shitty suspension and stock diff I wont be going anywhere till 2nd-3rd gear
Pretty sure Leigh's supercharged auto will demolish me from a standing start
Yay! I've decided to supercharge the 6L and car is booked in for the 30th to get the charger fitted and tuned :woot:
Decided to go for one of these bad boys, mainly because it looks stock-ish:
http://4.bp.blogspot.com/-NS_WDLsBZq0/T1_LQpRAIiI/AAAAAAAAAqk/OsyXOdfz1uY/s1600/stealthforce.jpg
Looks pretty inconspicuous despite the badging. How much power you expecting? Who is doing the tune?
Shitty skyline suspension > "above average" commodore/falcon suspension ;)
Yah, liking it cos there's no massive supercharger belt out front and almost everything is hidden under covers. Might have to find a way to cover up the badging, like vinyl wrap it or something haha Has 12" long inlet runners so apparently the torque gains are massive when compared to Magnuson and Whipple chargers.
MPW will be doing the work and specialise in boosting 8's. They installed and tuned the cam for me and I ahve been stoked with their service and attention to detail so far, so was a no brainer to hit them up again when I decided to go forced induction.
With the smaller pulley (10psi) and current combo, on 98 the tuner is confident for high 300s at the wheels. On E85, well over 400rwkw :)
vwlbc drags night on private track
AKA dandy factories
considering my ute is tail happy with maybe 130ish...I'ld hate to drive it!
admittedly holden don't have cart springs for rear suspension, but then they don't tow/hold as much.
now that in a sports wagon would be fun.
Yeah my car definitely be better off the line than on roll, the more gears I go through the better - dat auto gearbox ftw.
Or take your cars to the drags and try to better my current best of 11.61 :D
Do they still want $10k for that kit?
Did it come with any supporting mods? Injectors/fuel pump etc?
Seems a bit pricey for labour and essentially bolt-on parts.
Should just buy a couple of sss pulsars amiright?
  • Like 3
lol, nah im serious. i wasnt the only one who thought it was pricey, especially considering they quoted turbo conversion for the same price.
Yeah but think about the type of bloke who supercharges his commodore... they're probably almost all FIFO workers
  • Like 2
I have 4 mates with blown 8's (not inc sau peeps)
2 FIFO and 2 local tradies
Both FIFO workers lol
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
